Compare 3D Annotation in Creo Parametric and Pro/ENGINEER
DanMarotta
This video compares and contrasts the 3D Annotation capabilities in Creo Parametric 2.0 with equivalent capabilities in Pro/ENGINEER Wildfire 5.0.
This head-to-head comparison shows a range a typical tasks and activities, carried out using out-of-the-box versions, on the same hardware platform. The user has completed standard product training for both releases.
The 3D Annotation features in Creo Parametric 2.0 help users create and add 3D annotated views to their models helping minimize or even bypass the need for 2D technical drawings. In this comparison, the user dramatically increases design productivity, spending 58% less time performing the activity with Creo Parametric 2.0 compared to Pro/ENGINEER Wildfire 5.0.
Creo Parametric provides the broadest range of powerful yet flexible 3D CAD capabilities to help you address your most pressing design challenges including accommodating late stage changes, working with multi-CAD data and electromechanical design. Creo Parametric is part of PTC's Creo suite of design software.
Request a free copy of Creo Parametric and conduct your own comparison.
4 REPLIES 4
Question: can 3D annotation (created in Creo Parametric) be viewed in Creo View?
Reason for asking: we are working with WF4 and ProductView 9.1
If we add 3D annotation to our model, we are unable to show these 3D annotations in a ProductView file or 3D PDF.
Hello Teun,
This question may be better suited for @Madhavi Ramesh, the CreoView product manager. I've reached out to her. Hopefully she has a moment to swing by and provide a response.
Hi Dan,
So far no reply from Madgavi...I have tried to contact her too, but no response!
Could you "poke" her again?
Hello Teun,
In general 3D annotations created in Creo Parametric can be published and visualized in Creo View.  With that said, you seem to have issues with publishing/viewing 3D annotations in Creo View.  Can I suggest that you please open a Tech support call so we can investigate. Thanks.
