Compatibility issues between CREO & SOLIDWORKS
CS_10753153
2-Explorer
 I am working on the design using the CREO student version, and my colleague is working with SOLIDWORKS. A colleague handed over the .sldprt file, and CREO says, 'Unsupported file version.'
 In this case, is this a problem because it is a CREO student version? (The same problem is repeated for sldprt files that are readily available online.)
which Creo version?
which SOLIDWORKS version?
For example:
Creo 7.0.0.0 is able to open Solidworks 2019 files. You cannot open Solidworks 2020+ files
Martin Hanák
Hi, thank your for your support!
I'm using CREO 10.0 student version
and my 2 collegues using 2022 and 2023 each.
in this case, what will be matter for the compatibility?
https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp enables you to install Creo 10.0.0.0.
According to PTC KB Creo 10.0.0.0 is able to open Solidworks 2022 files.
Solidworks 2023 files can be opened in Creo 10.0.2.0.
Martin Hanák
