Component is family table driven and will use pre-Wildfire3 replace functionality
Dale_Rosema
This shows up frequently in the comment section of the models.
Is it good / bad?
Is there a way to "fix" it if it is not good.
What causes it?
Thanks, Dale
Dale,
There is an article CS61196 about this message, possibly resolution in that correct it.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS61196
4 REPLIES 4
Dale,
Mahesh Sharma
Is there a way to run that on individual files, or once I turn the config option, it will try to do that to everything?
Thanks, Dale
Dale,
This will be a manual process. Manually needs to update the files.
They are being updated as we come across them. Thanks, Dale.
