Component's ID
Dale_Rosema
Component's ID
I found a posting that showed how to find a component ID using a search tool. How do you get this tool to "pop-up"?
https://community.ptc.com/t5/Analysis/Search-a-part-by-it-s-ID/m-p/377183
Dale
Dale_Rosema
(To:Dale_Rosema)
Found it. Knew this would happen after hitting enter.
Under Tools, Click on the binoculars.
Dale_Rosema
(To:Dale_Rosema)
You can also add Component ID as a column in the model tree. It's easy to do and is very useful.
Dale_Rosema
(To:Tdaugherty)
Most of the time I do not need the ID. Only when I get the warning and need to find it in order to fix it. In this case (& I don't know why regenerating the assembly didn't work but) I needed to regenerate a subassembly pattern and the warning went away.
