This widget could not be displayed.
Config.pro option for assembly cut , intersection "Automatic Update"
HBreton
Hello All,
Is there a config.pro command which unchecks the Intersection, "Automatic Update" by default. I prefer adding the intersection models manually.
HBreton
(To:llie)
Unfortunately, that's not what I'm looking for. That only greys out the "Advanced Intersection "  option.  "Automatic Update" is still on by default.
But thanks for the reply.
7 REPLIES 7
StephenW
(To:HBreton)
I don’t believe there is on. I searched on Olaf’s config list and didn’t find any hidden ones that I thought might be available either.
https://creosite.com/index.php/configuration/config-pro-option-search/complete-lists-of-config-pro-options/
llie
(To:HBreton)
I believe you are looking for this option. I think this is the one that controls selecting the models you want the cut to go through. We have it set that the users have to add the models or the cut doesn't show up.
advanced_intersection no
HBreton
(To:llie)
Chris3
(To:HBreton)
auto_update_intersected_models no
HBreton
(To:Chris3)
Yes!  That works!  Thank you.
StephenW
(To:Chris3)
That's very nice. I've added it to my config!
pausob
(To:HBreton)
FYI, the find tool in the configuration editor sometimes works well to get you the answer:
