Construction lines drawn at the wrong place?
dorek
3-Newcomer
Hello Everyone,
I'm trying to solve this problem. I do the following:
- Create a new solid part
- Create a sketch on the FRONT plane
- Draw a Center Rectangle anywhere on the sketch (as seen on the screenshot "line_placement.png")
... and somehow the construction lines are showing up at the wrong place. They should be in the rectangle. Interestingly if I click on the diagonal of the original rectangle (where the diagonal construction lines should show up) the corresponding construction line is selected. So it is there, but drawn at the wrong place on the view.
If I rotate the view, it gets even worse. Please see "rotate_view.png".
Anyone had similar experience and knows how to fix it?
Dorek
1 REPLY 1
StephenW
(To:dorek)
I'm using Creo 4 M070 and I can't recreate the issue.
Some possibilities:
1. add this line to your config.pro GRAPHICS WIN32_GDI If it corrects the problem, you have a graphics card issue. Remove the line from your config.pro and try updating your graphics card driver
2. update your creo build code, sometimes there are problems that are fixed in a later build code
