is there any procedure to export a file from 3D model .asm or .prt to a .html file that can show the 3D model in a web-ready browser?
Thank you,
Michele Barile
Save a copy of the assembly model as 3DPDF format. UI selections are shown below.
Creo supports export of 3D pdf file format. This format can be viewed in most modern browsers (with a plugin).
Hello tbraxton, can you share with me the detailed procedure to do it?
Thank you,
Michele Barile
Ok tbraxton, that's the way to save a pdf 3D. However, how can I read it directly in a browser?
Thank you
