Corvette Callaway Renderings made in Pro/ENGINEER Wildfire 5.0: Coupe and Convertible
Dietrich, excellent renderings! How long did it take you to render?
-Dan
The renderings are super cool! Like the transperence too.
-Parag
I must say Just a Superb work done by you.
Thank you Dan. The rendering job took about 1-2 minutes (on a good workstation) and it took another 5 minutes to setup the model (colors, scenes, lights) with Wildfire 5.0.
So since WF 5.0 it's really easy ![]()
- Dietrich
Tremendous model! Great details. I think the lighting is a bit washed out, you may want to try using a more 'standard' studio lighting setup. Typically a large overhead area light for sleek reflections with some less powered additional fill lights.
Definitely a beautiful model to render with, I'm jealous.
As an example, here's one I did with a bit more environment.
Transparent one is awsome! Great work.
