Cosmetic Thread Issue
cdown
7-Bedrock
Guru's,
Right this one has me, I have a hole through half of a radius, it
has a cosmetic thread on it, however I can't seam to get it to show
correctly in my drawing as the thread start surface is the flat, hence the
thread starts after the radius. (attached document will explain what I
mean)
I have tried to then use the rad as a start surface but get a funny shaped
cosmetic, again attach doc will show this.
I seam to remember ages ago you used to be able to cut cosmetic threads
using a surface cut (if memory serves) but have not been able to do this.
Does anyone have a work around for this?
Regards
Colin Down
Mechanical Design Engineer
Email: -
Tel: +44 1305 208503
The information in this e-mail and any attachments transmitted with it are provided in commercial confidence for the intended recipient(s). If you have received this e-mail in error, please notify the Postmaster by e-mail at -. Any views or opinions expressed are solely those of the author and do not necessarily represent those of DEK.
For local company specific legal information for your country or region and any local contact information for DEK, please refer to:
0 REPLIES 0
