Cosmetic Thread of drafted surface
himungan
6-Contributor
When i apply standard type of cosmetic thread on drafted surface, depth value is grey out as seen in screenshot available in attachment
kdirth
(To:himungan)
You need to select the surface to start the thread from first (end of the cylinder).
Also, it has defaulted to a tapered pipe thread which has a standard length.
himungan
6-Contributor
(To:kdirth)
No difference. It is just the reference for depth value
kdirth
(To:himungan)
If you are trying to create a standard straight thread on a drafted cylinder, you need to create the cosmetic thread then draft the cylinder.  Otherwise Creo defaults to a tapered pipe thread.
himungan
6-Contributor
(To:kdirth)
However some standard not seen without drafted surface such as NPTF and NPF standards.
