Countersink name enabled at the IFX UI
LS_10690167
6-Contributor
IFX definition window allows to modify the countersunk diameters while using countersink head screw but UI we can find only counterbore , we need this countersink name enabled at the IFX UI level”
Hi LS_10690167
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
LS_10690167
6-Contributor
(To:achirila)
Hi achirila ,
Subject: Enhancement Request: Addition of Countersunk Name in IFX Hole Definition Window
I wanted to express my gratitude for your prompt response to my previous request.
I have attached an image of the IFX UI window for your reference. While reviewing the IFX definition, I noticed that it currently allows us to modify the countersunk diameters when working with torx head screws. However, I observed that only the counterbore name is visible in the hole definition window.
Considering the importance of user convenience, I believe it would be beneficial to make users aware that they can also modify the countersunk value. Therefore, I kindly request to include the countersunk name in the IFX hole definition window for easier accessibility and user-friendly navigation.
Your attention to this matter would greatly enhance the usability and efficiency of the system. Thank you for considering this enhancement request.
Thank you
