This functionality seems to have stopped working for me. Typical bulk items will not accept balloon creation, either for the stock simple circles nor custom split balloons.
There was a video posted as a solution to this awhile back from @bduncan , but I can't seem to get to it.
Creo 4 M100
Any help is appreciated.
you can add following special drawing option to your drawing:
update_drawing all
You have to enter this option manually in Creo dialog box. Do not save the drawing automatically. The above mentioned option can cause unexpected problems.
If this option resolves the problem then this means that your drawing is corrupted somehow. I suggest you to create new drawing.
Hello @PapasaurusPrime
If value all for the update_drawing entry is not wished (to avoid losing control of what is being fixed with this "all" value), and impacted repeat region attributed is set to No Duplicates, the update_drawing values 1144731 and 1820521 may be enough to fix this.
=> Refer to article 17253 for further technical details.
Serge Acquarone
Thank you for this Serge. Although it didn't work, it's very specific to my problem, and the hidden option will come in handy.
I am working for PTC Technical Support (just for info), and was also unable (like you) to access the video you mentioned in legacy post upon creation of this post.
Please allow me to share additional guidance as follows:
Additional documentation:
My suggestion:
Hope this helps as next step.
Serge
Thank you Martin (and Serge) for your reply. However, I'm still not having any success. I will have to troubleshoot further, as I had this working a year ago or so. We recently updated our tables and balloons, so the answer may lie there somewhere. Although, the changes were nothing drastic.
