i want to generate drawings for all the parts in the assembly having general arrangement by using a single template, i.e. on the first page, general arrangement of assembly, and on a second page and further, parts of the assembly.
I think it is not possible using OOTB functionality.
Too many variables involved in building a template like that.
Are all assemblies built with the same number of components? This would determine how many sheets you need.
Are all assemblies and components the same relative size? This would determine the view scaling needed for each sheet.
Many other factors that make a drawing from a template complicated. You might be able to do it with a custom toolkit application.
