Create smooth variable draft across multiple surfaces
Is there an easy way to create a smooth variable draft when there are several surfaces of varying length?
Here is a simplified example of the issue:
The drafted surface is made from several segments of different length and the draft hinge is the edge of those segments. It appears that Creo is splitting the change in draft angle evenly over each segment rather than over the length.
Is this what the draft feature is expected to do? I was expecting it to smoothly make the variation over the full distance.
Creo 7.0.8.0
