Creating Closed Volume from Seed / Boundary Surface
akelly
I created a surface copy using the seed / boundary surface technique. I
want to solidify it, but it needs to be a closed volume. What's the
easiest way to "cap" the ends that were created by the edges of the
boundary surfaces?
Note: Creating fills, extrudes, revolves, seems a bit tedious.
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics |
+1 440 326 5555 | F: +1 440 284 1090
6 REPLIES 6
My system admin asked:
"Any chance we could get away with the nVidia Quadro 2000 instead of the
4000? Let me know."
I don't want to "cheap out" on the tools I use daily. But do I really
need it? He thinks there is $400 difference between the 2000 & 4000.
Thanks.
--Tom Carrington--
Rexair LLC
231-876-3932
This email and any attachments are confidential and may be legally
privileged. If you are not the intended recipients, please notify
the author by replying to this email message, and then delete all
copies of the email on the system. If you are not the intended
recipient, you must not disclose, distribute, copy, print or use
this email in any manner.
Email messages and attachments may contain viruses. Although we
take precautions to check for viruses, we make no assurances about
the absence of viruses. We accept no liability and suggest that
you carry out your own virus checks.
BenLoosli
(To:akelly)
A lot will depend on what you do with WF.
If you only make boxes and tubes and a drawing, the 2000 will be more than adequate.
If you do complex surface shapes and assemblies of 10K+ components, the 4000 may not be enough.
Our new Dell R5800 with FX100 head running win7-64 has a 5000 in it, very nice machine.
Thank you,
Ben H. Loosli
USEC, INC.
bgruman
(To:akelly)
I guess it all depends on what your doing with it, but for me, I just need
to look at the specs... (see attached)
More Cuda Cores, twice the memory and bandwidth...
What's $400 compared to 3-5 years of user comfort and speed over the life of
a machine?
Just my .02
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
On Mon, Aug 22, 2011 at 2:09 PM, Carrington, Tom
<->wrote:
> My system admin asked:****
> “Any chance we could get away with the nVidia Quadro 2000 instead of the
> 4000? Let me know.”****
> I don’t want to “cheap out” on the tools I use daily. But do I really need
> it? He thinks there is $400 difference between the 2000 & 4000. Thanks.***
> --Tom Carrington--
> Rexair LLC
> 231-876-3932
davehaigh
(To:akelly)
Perhaps Olaf's benchmarks will provide you better data to make your decision.
These are ranking for graphics
Searching for: Quadro 2000 Sub-total:Graphics
Rank
Score (secs)
Make
Model
Processor
Speed
Graphics
RAM
OS
Version
Build
71
958/2613
Dell [cid:image002.png@01CC60CE.8DDD1EB0] <">http://www.proesite.com/OCUSB5/certified.htm>
T3500
Xeon W3530
2.80GHz
NVIDIA QUADRO 2000 8.17.12.6766
8.00 GB
Windows 7 Enterprise Version 6.1.7600 Build 7600
Wildfire 4.0
M160
102
1039/2854
Dell [cid:image004.png@01CC60CE.8DDD1EB0] <">http://www.proesite.com/OCUSB5/certified.htm>
Precision T7500
8 Core Intel(R) Xenon(R) E5630
2.53 GHz
NVIDIA Quadro 2000
24 Gb
Windows 7 64bit
Wildfire 4.0
M180
114
1081/3138
Precision T3500
Dual Core
2.53/GHz
NVIDIA Quadro 2000 1GB
6GB DDR3 ECC SDRAM
XP 64 v5.2.3790
Wildfire 4.0
m160 x64
Searching for: Quadro 4000 Sub-total:Graphics
Rank
Score (secs)
Make
Model
Processor
Speed
Graphics
RAM
OS
Version
Build
67
939/2887
Dell
T3500
Intel Xeon X5660 1366LGA
2.8Ghz
Quadro series 4000 266.45
6Gb
Windows Seven 64Bits
Wildfire 3.0
M220 X64
70
952/2682
Dell
T3500
Intel Xeon E5630
2.53GHz
NVIDIA Quadro 4000 dv:259.93
12 GB
Win XP Pro x64 SP2
Wildfire 4.0
M110
172
1447/4419
Sun Microsystems [cid:image002.png@01CC60CE.8DDD1EB0] <">http://www.proesite.com/OCUSB5/certified.htm>
Ultra 40
2 Dual Core AMD Opteron
2.41 Ghz
Quadro FX 3450/4000 SDI
8GB
Win XP Pro x64 Edition
Wildfire 2.0
M160
194
1682/5692
HP [cid:image004.png@01CC60CE.8DDD1EB0] <">http://www.proesite.com/OCUSB5/certified.htm>
XW8200
Xeon
3.20GHz
NVIDIA Quadro FX3450/4000SDI Ver. 5.41.02.50.05
8GB
XP Pro 64 Bit
Wildfire 3.0
M110
195
1798/5848
Dell
Precision PWS 690
INTEL XEON
3.20GHZ
NVIDIA QUADRO FX 3450/4000 SDI BIOS 5.41.02.50.05
16GB
XP 64 V2003 SP1
Wildfire 2.0
64BIT M180
196
1798/5991
Dell
pws690
intel xeon
3.2Ghz
nvidia quadro fx 3450/4000 sdi
16gb
64 bit XP professional SP1
Wildfire 2.0
m180 x64
198
1875/4932
HP
xw6400
Intel Xeon 5130
2.0 GHz
Nvidia Quadro FX 3450/4000 SDI
8 GB
Windows 7 64 bit
Wildfire 4.0
M140 64 bit
These are the CPU sub scores
Searching for: Quadro 2000 Sub-total:CPU
Rank
Score (secs)
Make
Model
Processor
Speed
Graphics
RAM
OS
Version
Build
71
1800/2854
Precision T7500
2.53 GHz
NVIDIA Quadro 2000
24 Gb
Windows 7 64bit
Wildfire 4.0
M180
121
2049/3138
Precision T3500
Dual Core
2.53/GHz
6GB DDR3 ECC SDRAM
XP 64 v5.2.3790
Wildfire 4.0
m160 x64
207
20113151/3204
Lenovo [cid:image002.png@01CC60CE.8DDD1EB0] <">http://www.proesite.com/OCUSB5/certified.htm>
W520
i7-2720QM
2.2GHz
NVidia Quadro 2000M 268.71
8Gb
W7- X64 Professional
Wildfire 4.0
M130
Searching for: Quadro 4000 Sub-total:CPU
Rank
Score (secs)
Make
Model
Processor
Speed
Graphics
RAM
OS
Version
Build
56
1723/2682
Dell
T3500
Intel Xeon E5630
2.53GHz
12 GB
Win XP Pro x64 SP2
Wildfire 4.0
M110
95
1908/2887
Dell
T3500
2.8Ghz
6Gb
Wildfire 3.0
M220 X64
179
2960/4419
Ultra 40
2.41 Ghz
8GB
Wildfire 2.0
M160
180
3038/4932
HP
xw6400
Intel Xeon 5130
2.0 GHz
8 GB
Windows 7 64 bit
Wildfire 4.0
M140 64 bit
200
3997/5692
XW8200
Xeon
3.20GHz
8GB
XP Pro 64 Bit
Wildfire 3.0
M110
201
4034/5848
Dell
Precision PWS 690
INTEL XEON
3.20GHZ
16GB
XP 64 V2003 SP1
Wildfire 2.0
64BIT M180
202
4176/5991
Dell
pws690
intel xeon
3.2Ghz
16gb
Wildfire 2.0
m180 x64
David Haigh
Hi Tom,
If I step to one side one the exact capabilities of each card I can ask the
question; does my employer value me?
What I mean by this is you are having a discussion over $400 when this is
probably less than 1% of your annual salary so how does your employer see
your value? Obviously no-one wants to pay over the odds for anything, and
CAD equipment is no exception, but long gone are the days when a new
workstation was around half your salary; this is now in the order of 5%, or
10% tops, so it makes no sense for companies to scrimp on what they provide
even if you only think of this in terms of motivation. Of course this does
not mean the sky is the limit and when I look at specifying new machines I
do keep an eye on the price and try to balance value against performance.
I suspect though that either card will serve your purpose unless you are an
outlier with massive assemblies as suggested by another reply.
All that said I am looking at Dell M6600 with the NVIDIA 3000M card as this
is already a giant step up on the FX1400M in our M6300 machines that are two
and a half years old 🙂
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
Yes, and lets put some numbers to this? IF we assume a $50,000/year salary, a workstation that cost $5000, and has a "life" of 2 years... That's 5000/(2*50000) = 5%.... NOW add in the building, benefits, support staff (accounting, HR, managers, sales...) AND consider that most likely you're on your workstation somewhere between 90-100% of the time; and that 5% is further reduced...
IT is pissing over $400... sad... sad... sad... "Any chance we could get away with..." NOT having idiots in IT??? 😉 Talk about penny wise and dollar foolish...
OH, and note that I think $50k/yr is pretty darn low, at least for a degreed design engineer... AND a $5000 workstation is incredibly HIGH... We're running HP z600's with FX4000, 12 gig ram that I think run around half that, though we lease them for business reasons...
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
