I must be losing my mind.
Didn't Creo used to allow making a Diameter dimension in drawing mode of a side cross section edge or point using the 3 mouse clicks just like you can in part sketcher mode?
I have a cross section view of a part that I want to CREATE a diameter type dimension from a centerline to an edge. The entity was not made in the part mode with that feature dimensioned as a diameter so I cannot just show the dimension.
In part sketcher mode, you can easily make a diameter dimension by left clicking the edge, left clicking the centerline, then left clicking the edge a second time and placing the dimension.
I swear the exact same steps could be done in drawing mode when making an annotation dimension but it is not working. I am using Creo version 7.0.5.0 and all it does when I perform those clicks is try to make a length dimension of the edge itself, not a diameter dimension.
Yes, you can do this, but lately it's been a little buggy for me. Let me know if it works for you.
I'm on 9.0.6.0 but I know it has behaved this way in prior versions as well. Hopefully it's been fixed in later versions.
Hi @DC_6935478,
Anurag
