Creating stickers & label
Wheelsofsteel
Hello
I have an issue.
I currently have to create painting & labelling drawings for our products, which have to show where to paint, where and what type of sticker to apply, and what color stripes to paint on the OD.
The problem is, the surface is round and tapered, I have tried to wrap text to the surface but not very successfully due to the tapered surface, and the same with the stripes.
I am doing the drawing, outputting as PDF, then importing into PowerPoint and wrapping shapes onto the drawing and resaving as PDF. it works but I would like to do it within Creo if I can.
I was thinking if I create a sticker as a part then assembly it to the model, but can I wrap the part to the round & tapered surface.
Does anyone know a better way to create stickers & stripes on a part.
Peter
tbraxton
(To:Wheelsofsteel)
Applying decals is an option to handle this.
https://community.ptc.com/t5/PTC-Education-Forum/Working-with-Images-and-Decals-in-Creo-Parametric/td-p/91321
Involute Development, LLC
Consulting Engineers
6 REPLIES 6
tbraxton
(To:Wheelsofsteel)
Hello Tbraxton
I have just found a way to do this.
Creo 9 has a feature that allows you to divide surfaces.
see youtube video
Creo Parametric 9.0 - Divide and Unify Surfaces
https://www.youtube.com/watch?v=89YwzwPZxQg
this has allowed me to use the decal option
decal on a tapered surfacedecal on a tapered surface
Thank you
tbraxton
(To:Wheelsofsteel)
I would not apply high fidelity representations of artwork in Creo. The method I defer to with these situations is to document the location of any artwork (label) in the model/drawing with a shape of the outline and use a note to make reference to the artwork, label etc. Assume the label is a rectangle then just apply the outline to the model which would appear as a box wrapped on to the taper.
For paint call outs I would create surface regions and color code them to indicate where the paint is applied. This can be shown with shaded drawing views as well as displayed in the 3D models.
An example label callout:
Hello Tbraxton
I did start doing this, but the manager wanted the exact sticker on the model to avoid confusion at the finishing line.
Hello Dale_Rosema
I had tried this option, but it looked messy as the surface is round & tapered.
I now have a solution that works.
Thank you for you reply
