Hi, I am trying to run a simple stress analysis on an assembly using a static analysis, but I keep getting the error:
"The model is insufficiently constrained for the analysis. Please review the element connections,
properties, and constraints in highlighted entities. If this is a modal analysis, then you may be
able to obtain a solution by requesting additional modes."
Total Assembly:
Latch:
Pin
Error
I have defined:
-materials
-surface-surface contacts
-hole constraint in all directions on latch
-surface constrait on all pin surfaces in all directions, except X (same direction as load)
I tried doing the same analysis on a single part (rather than an assembly) and it works fine.
Does anybody have any ideas how to resolve this issue?
Thanks a lot
Mark M.
Mark,
Make sure the material files have Denisity, Young's Modulas, and Possions assigned in them.
Don
Mark,
Is the latch fixed so that it can't move using a displacement constraint?
I'm assuming the pin has some freedom to move. The pin is fixed in what directions using a displacement
constraint?
Don Anderson
Mark,
Don
and Yes, both parts were assigned steel from the material library and they have those 3 properties.
The latch is constrained in all directions in that hole using a displacement constraint.
The pin in constrained in all directions except X (same direction as load arrows in first picture) using a displacement constraint.
The reason the pin is much more constrained is because the error screen always points to the pin "elements" (as seen on the Error picture), so I tried many different constraints:
-Surfaces---->Individual----->Surface Set (all surfaces on pin)
-Surfaces---->Boundary
-Curves/Edges
-Points
Heres some other views of the error:
Thanks Don.
Mark,
Take a look at the attached file. It might give you some ideas.
http://communities.ptc.com/servlet/JiveServlet/downloadBody/2722-102-1-3146/asm0001.asm.zip
Don
Thanks but I only have the student version of Creo, not the commercial one so it wont open.
Mark,
Upload your files and I will take a look.
Don
I figured it out, it was a material property issue. Thanks a lot
Hi Mark,
Now I also get this kind of problem. Could you kindly tell me the detail about the material property issue.
Thanks a lot.
Raphael
Dear Sir,
I made a tank model which is closed all side and applied pressure from inside, during analysis model failed in meshing, while check in review geometry and auto-gem, there is no error, please solve this issue
i had already check factors Denisity, Young's Modulas, and Possions.
