In Creo 10.0 and above, when converting stp files, am I not able to set the coordinate system?
Please let me know if there is a way to set it with the coordinate system I made
Choose the customize export option when exporting the STEP file. This will invoke another window that has the selection of the csys used for export.
Hi @SJ_11312555,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
