Creo keeps shutting down because of this error. I have the student version and it basically says that it doesn't have "enough" access but I have already allowed it to communicate through my firewall. Plus, I uninstalled and reinstalled the diagnostic tool and it still won't work. I'll be really grateful ofr any suggestions on how to fix it. Thanks!
Error message ↓
Thanks for the reply! Sadly I have no clue what is and how to set an environment variable and can't find the creoagent.exe file. I looked for it in the installation directory but didn't find it. Do you have suggestions on where to start? Thanks again : )
try following (paths are related to Creo 11.0):
What Creo version are you installing?
The above procedure assumes that only one Creo version is installed.
