Creo 10 "auto refit" in large .asm when creating first feature
trailFileFnatic
Version: Creo 10.0.1.0
Problem:
I am working on a large .asm > create new empty part > activate this .prt in .asm > create a first feature (sketch, extrude, anything) > click on OK in the sketch > and creo zooms out (the larger the .asm is, the further creo zooms away).
This behaviour occurs ONLY for the first feature in a new activated part. Once the .prt has any feature, creo does't do a "auto refit" when exiting the next feature sketch with Ok.
Did anyone ever encounter that problem? I asked my reseller (and PTC), but nobody can replicate this type of behaviour. I tested it here in the company I am working and it is the same problem on every CAD workstation. I started Creo vanilla, without any setting and still the beviour occurs.
Here are some screens. I created a large .asm (75m x 75m) by pattern a random testpart:
Active a new empty part and create a sketch:
As soon as I hit "OK" in the first sketch, Creo zooms out. So far, I can't even see the .asm on my screen anymore:
Just to close this topic, here is my workaround: I added a sketch to my startparts with a single point. Put that sketch on a hidden layer. This empty sketch in the startpart is preventing the "jump-zoom" when creating new parts in assemblies.
I still hope, that PTC fixes this bug in future releases.
8 REPLIES 8
That's the Creo Confusion option. I comes as a standard feature and you don't even have to pay extra for it!!
I'm on Creo 6. I don't see the same but it does re-zoom to fit the entire assembly upon completion of the sketch (or extrude).
Chris3
(To:StephenW)
This is related to the auto-scale of the first sketch feature in Creo 9. I just completed the same steps in Creo 9 though and didn't get that result. I would open a ticket with PTC and submit your example parts.
aputman
(To:StephenW)
I also have that feature.  I wish it was a paid feature because I would not buy it.
Chris3
(To:aputman)
Our users like that feature. I don't know if it will fix this issue in Creo 10 but it can be turned off
sketcher_auto_scale_dimensions no
aputman
(To:StephenW)
I had a different situation in mind where the model zooms on me when I don't want it to.  I can't think of what it is at the moment...guess I have learned to deal with it.  But there is a config option for the behavior described above.  The fact that it zooms to such a large scale doesn't make sense unless something is located way out there that is setting the bounds for the autofit.
sketcher_refit_after_dim_modify  -  Refits section after dimension modification in 2D section or when creating the first feature.
Thanks for the replies. I tried the config options but none of them solved the problem.
Though I am confused. As far as I know this behaviour "first-feature-assembly-auto-scale" is a bug, caused by graphic card driver or config setting or API setting...or something else.
I was hoping someone else had to deal with the problem and found a solution. Already asked my reseller, but they don't know what could cause this refit behaviour, nor where they able to replicate it. I just want Creo to "stand still" while I am working and not zoom out, in or anything.
You need to log a ticket with PTC not your reseller.
https://www.ptc.com/appserver/cs/portal/
click OPEN A SUPPORT CASE
