Hi @CA_10146793
Thanks for the update. I agree missing Conflict dialog can lead the confusion as in your case.
About $F2, default assignment of F2 is to Rename, but that can clear from Windows Shortcut. Created a sample mapkey with keystroke F2 and that worked well for me with keyboard input. If possible share the F2 mapkey to review.
please report described behavior to PTC Support.
I have confirmed the behavior in Creo 11.0.0 and also confirmed this does not happen in Creo 9. I agree with @MartinHanak - you should open up a ticket with PTC so they can file a bug report (SPR).
Thank you both, case opened. I first posted on the forum as per initial action suggested by PTC support "bot". Additionally:
Thank you Mahesh.
FYI all:
The cause appears to be that new keyboard shortcuts for shift 1-3 were released in Creo 11. I did not initially detect the conflict - new keyboards shortcuts; they can be easily seen by "Show/Commands with assigned shortcuts" in Options. However Creo did not alert me to any conflicts, which was the behavior in Creo 10 where the user was given the option to automatically resolve detected conflicts. Resetting the keyboard shortcuts to default did reveal conflicts and prompt to resolve.
I am also checking into the reason for why $F2 mapkey can no longer be triggered by the keyboard in sketch mode (have not yet identified keyboard conflict).
Hi @CA_10146793
hi @Mahesh_Sharma ,
Thank you for the feedback. I agree that $F2 in general works for in most mapkey cases, but for some reason it does not work in my unique mapkey case which is only applicable while in a specific menu state or "mode". I've attached the mapkeys in question. There are two that are triggered in sequence; OE and $F2. $F3 is an exact copy of $F2. Here is an example below to reproduce the issue - the goal is to be able to create a quick offset sketch by complete loop, using mapkeys sequentially to reduce mouse clicks:
Rather than pursue this further, my workaround is to simply use $F3 and avoid $F2 for this particular mapkey. I do not know the root cause...it seems like another keyboard shortcut conflict but I can't find any. It would be good to be able to use $F2 but perhaps my workflow on this offset command is somewhat specialized, so I am OK with closing the case.
Hi Mahesh,
I have now seen the Resolve Conflict dialogue successfully pop up in 11.0.2.0. However even after deleting F2 Shortcut Key from "Rename":
F2 keyboard shortcut is already assigned to a mapkey:
(Mapkey Name)
You cannot use the same shortcut for a command and a mapkey.
Go to the Mapkeys dialog box.
This seems similar to the error reported in SPR 6985210.
