Creo 2.0 crashes with measure tool
GC_1679608
2-Explorer
I recently install Creo parametric 2.0 due to customer request. When I use the measure function, the program crashes.
I also use Creo 6.0 but this problem does not arise. Maybe some problems with graphic settings.
Thank you in advance.
Marco
StephenW
(To:GC_1679608)
You can try the adding the graphics options in your config.pro. (you have to manually add the option, it's hidden, so it doesn't come up in the list)
GRAPHICS WIN32_GDI
If it works without crashing, it is a graphics issue, remove the option and try updating your graphics card driver.
2 REPLIES 2
StephenW
(To:GC_1679608)
GRAPHICS WIN32_GDI
Thank you Steve,
I change the graphics settings from OPENGL to WIN32_GDI. Now Creo 2.0 works without crashing.
When I installed Creo 6.0 I had the same problem, but after updating graphics card driver, everything was fine.
Maybe the updated drivers don't support an old version like Creo 2.0.
In the end, I think I will use OPENGL setting for Creo 6.0 and WIN32_GDI for Creo 2.0 (I use two different config.pro).
Thanks again.
Marco
