Creo 2.0 doesn't launch
ptc-4677759
Hi Guys,
I downloaded the trial version of Creo, installed it and Parametric doesn't run. ModelCHECK launches and appears to run. Quality agent runs (info pasted below) but when I try and run Parametric, nothing happens.
Is there an error log somewhere I can check?
System info:
Hardware Information
Manufacturer Dell Inc.
Platform Type
System Latitude E6320
Processor Manufacturer GenuineIntel
CPU Number Of Cores 2
Speed Mhz 2501
L2 Cache Kb 256
RAM MB 4096.00
3GB Switch true
SWAP GB 3.88
DISK Label C:
Size GB 127.01
Available GB 45.07
FileSystem Type NTFS
DISK Label 😧
Size GB 105.10
Available GB 37.11
OS Information
OS Name Microsoft Windows 7 Professional
Vendor Microsoft Corporation
Version 7601
Locale 1009
Indexing Services OFF
Animate Controls ON
Animate Windows ON
Fade Menus ON
Graphics Information
Name Intel(R) HD Graphics Family
Vendor Intel Corporation
Version 8.15.10.2418
Screen Resolution 1366 x 768
System Colors 32
AERO Enabled ON
So a full uninstall and re-install did the trick. Work uses a VPN through another country so my connection was very slow and I kept getting errors during the download (5 times then gave up). Trying from home worked great.
Installed and up and running.
