Hi all, My company recently upgraded to Creo 2.0 from WF5. So far Creo seems kinda buggy. Currently doing a drawing and cannot get Creo to use drawing colors vs colors from model. Anyone else have this issue ?
This is an option in the View Properties. Haven't used it but does this not work as expected?
In Creo 2.0 M040... It seems to work fine. Is your model assined a color or are the surfaces colored different from the model?
...and welcome to the forum, William!
Thank you !
Antonius, You are correct. Colors from drawing option has no effect. We are using build M050. I have not found any way to change the colors of the geometry on a drawing other than changing the model colors. This is a big issue on assembly drawings.
Have the same Problem - Still no solutions?
Andreas,
I did quick test in CR2 M070 and realized that Colors coming from options work well. Can you provide more details/pictures ?
Martin Hanak
