Creo 2, M100 Build
EricH
7-Bedrock
Creo 2, M100 Build
Has anyone upgraded and noticed any issues with the M100 build? Specifically not being able to activate Datums, Axis and Coordinate Systems?Creo2-M100.JPG
EricH
7-Bedrock
(To:EricH)
We traced this back to a conflict between the Config.Pro and Config.Sup files. What surprised me was; nothing was changed from the M090 versions but for some reason the M100 build didn't like the setup.
7 REPLIES 7
Dajagwar
3-Newcomer
(To:EricH)
We just upgraded, and we do not have that issue. M100 actually fixed a lot of our issues.
Inoram
(To:EricH)
Same, I'm on m100 and have not seen that issue.
TomD.inPDX
(To:EricH)
I had this happened in M040 for some odd reason. Re-activating the part fixed it. Very odd and rare occurrence.
EricH
7-Bedrock
(To:EricH)
ngiacom
(To:EricH)
How did you solved the issue?
I have the same problem, but I don't understand how to fix it.
EricH
7-Bedrock
(To:ngiacom)
We had to comment out the following lines in our Config.SUP
! display_axis_tags yes
! display_coord_sys no
! display_coord_sys_tags yes
! display_planes no
! display_plane_tags yes
Speaking w/ PTC, one of the fixes between M090 and M100 highlighted this issue for us. Everything works fine, as expected. Hopefully this is your issue as well.
ngiacom
(To:EricH)
It works, thank you.
