We made some tests and looks like when open complex assembly in Creo 2 several times work and then exit form Creo memory occupied stands on 1-2 GB more than before using Creo. It is looks like Creo doesn't release memory correctly. It can be very dangerous, since several restarts of Creo can exhaust memory resources even you have plenty of memory.
In Reply to Zeev Tsesarsky:
Your issues with Creo 2 and PDMlink may be due to the fact Creo 2 is not supported with PDMLink 9.1 until M070.
We are just about to start testing Creo2 (with 9.1 m070) so will be interesting to see what we find.
Cheers
Simon Lucas
In Reply to Simon Lucas:
Cheers
Simon Lucas
Simon,
I'm using Creo 2.0 with PDMLink 10.1 and Wildfire 5.0 with PDMLink 9.1 and both are supported.
