Creo 3.0- How can I see active Constraints?
bpenza
8-Gravel
I'm doing a helical sweep with tools-relations formula.  I know this works since I have done it several times. However, it is failing in this one particular situation because there are constraints in place on the sketch.
Of course, I never put the constraints in, they were automatic.
The question is, how can I see what these hidden constraints are?   Is there an option that shows me constraints?
I know sometimes a window will pop up to show this or they are displayed on the drawing view,  but sometimes it seems that the constraints are actively preventing an operation or feature and they seem to be hidden from my view.
So, again, is there a screen somewhere that will show and allow deletion of drawings constraints?
Thanks.
mbonka
(To:bpenza)
Hello @bpenza
 do you mean constrains in sketcher? If yes, try following:
1. go to sketcher
2. roll up setup menu
3. choose display
4. turn on/off what you need
See attached picture
Regards
@mbonka
1 REPLY 1
mbonka
(To:bpenza)
Hello @bpenza
1. go to sketcher
3. choose display
Regards
@mbonka
