Hey All!
My Creo Parametric 3.0 M030 is not responding after 2 seconds in the program..
I re-installed everything already, nothing worked .It got even worse. After the first Install of the program it was just lagging like hell every 5 seconds but it was working. Now after I installed it again it wont work at all.
I run windows 8 and I have the recommended specs on my Computer.
- 16Gb DDR 3 RAM
- ATI Radeon HD7950 3Gb Boost
- SSD (where also Creo is installed)
- I5-3570K
If i run other programs like Creo Layout or Direct it works like a charm...but not the important program Parametric ![]()
Please Help!
Alex
I got it now! Even with the Creo 3.0 M030
You need to change a parameter in your config.pro located ...\PTC\Creo 3.0\M030\Common Files\text
and add "graphics win32_gdi"
now it works like a charm!
Regards
Alex
My colleague had same problem with M030. We reverted him back to M020 untill we figure the problem out.
Thanks for the quick reply. I know it sounds stupid but i cant find the M020 version.
I got the student license. I can either download the 3.0 M030 or the 2.0.
how about the graphics config setting?
opengl or win64?
I will try to change the settings. Thanks for the answer
Regards
Alex
