Creo 3 Common Folders Tab
llie
All,
In Creo 2 we taught our users that the fastest way to start using your workspace tied to Creo is to do the following
Open Creo
Select Common Folders tab (located above the model/drawing tree)
Select Workspace
Log into Windchill pop up
...and they are done
In Creo 3 M030
Open Creo
Select Workspace
...and Creo Parametric says (Not Responding)
Does anyone have any suggestions?
Thank you,
Lance
TomU
(To:llie)
Something definitely changed with Creo 3...
Have you tried using File --> Manage Session --> Server Manager? Maybe see if that performs any better.
llie
(To:TomU)
The same thing happens using File --> Manage Session --> Server Manager.
I can only log into the embedded browser, select my workspace, and then Activate the workspace from the embedded browser.
TomU
(To:llie)
Is this just one computer or all of them? Are you on the same physical network as the Windchill server? (Not on a VPN.) Do you have any Anti-Virus software or Firewall software that might be causing problems? (Try disabling both.)
TomU
(To:llie)
Is the Creo Agent starting? Look in Task Manager and see if you see creoagent.exe listed.
Creo will also gripe if it doesn't start:
I'm doing some VPN testing and disabling the creo agent seems to cause the same type of behavior you're experiencing.
