Creo 4.0 - Drawing - only single dimenson selection
SJI
Hello all together,
Example: in Drawing Modus
In Creo 2.0, when i create dimension by dimension then i lay down, they selected all the dimenson i created and i can select tolerance 4 all these selected dimension´s.
Now in Creo 4.0
They only select the last dimension i created.
See attached Video
I know that i can select all with a window, but if there some diameter between i select it too.
Thanks 4 help.
cheers
Stephan
Mahesh_Sharma
22-Sapphire I
(To:SJI)
A new config has been introduced ( in Creo 4.0 M040) to get this as in earlier versions, set select_newly_created_dims to yes.
Check article  CS272125
1 REPLY 1
Mahesh_Sharma
22-Sapphire I
(To:SJI)
