Creo 4.0 M060 - Can annotations in combination states from a model be shown on a drawing?
cscouller
8-Gravel
We have recently upgraded from Creo 3.0 M120 to Creo 4.0 M060.
I have been modelling a part and started to generate a drawing for this, is it possible to use combination states in the models and then use these in the drawing sheets? The simple answer is Yes you can and I have established this however if on my combination state 1 I have certain annotations visible and I want to display these on the drawing how would I do this?
If I select show annotations in the drawing on that specific view that is using the combination state it still displays all annotations for the part (This would result in duplicated effort) is there a method of showing only the annotations selected in the models combination state? Is there a config setting or have I missed something very basic?
Annotations from combination states can be shown in drawings using Config option:
option auto_show_3d_detail_items yes
Yes is the default so this will also work as long as it is not explicitly set to NO
Annotations will only appear from combined view aligning with the basic orientations front, right, left, top, and bottom, and each annotation will only appear once, if a dimension is already placed on the drawing it will be omitted from the drawing view for that combined view.
Once the view is placed it will not add or remove annotations based on changes to the models combined view, likewise changes to the drawing view will not effect the models combined view.
Annotation position can be restored through the "restore 3D dependencies" option.
5 REPLIES 5
@cscouller
I tested this in Creo 4.0 M080 and seems working for me. Added couple of annotation in front orientation in default or new combined state and that displayed in drawing without any duplicate efforts.
Additionally refer
https://www.ptc.com/en/support/article?n=CS254422
https://www.ptc.com/en/support/article?n=CS273062
Thank you!
We are awaiting deployment of Creo 4.0 M080 from M060 - when we have this I will test.
@cscouller
Just to clarify about my test. In my test I created a part with some combined states and added and created some annotations. When creating views in drawing, it displayed the annotations from combined state.
Hi MaheshSh
I'm working with @cscouller on this problem. I have managed to get a hold of M080 for testing, but cannot see a way to pull annotation visibility along with the combined view. It will automatically bring orientation and sections from the model and annotations are available, but must be filtered out in the drawing tree to mimic the model tree annotation. Is this what you see in your test or are you able to drop a fully annotated drawing view down as per the combined state with no additional showing or hiding of annotations. If so is this a setting or option we have missed.
thanks
Dave.
