Creo 4 - Use Datum Planes for Broken Views
HamsterNL
18-Opal
I'm afraid that the answer is no...but can I use Datum Planes as the references for my Broken View?
3 REPLIES 3
kdirth
(To:HamsterNL)
Only as a visual reference when making the broken edges.  References are limited to edge lines of the part.
I think NO is the right answer ... perhaps because the reference must allow the view to be divided in both the vertical and horizontal directions.
Martin Hanák
pausob
(To:HamsterNL)
Well, instead of planes, why not use datum points?  Those can be used as references for placing the split lines in a broken view (tried with Creo 4)
