Creo 4 linear diameter dimension - how to rotate
ptc-170698
3-Newcomer
kdirth
(To:ptc-170698)
Change the configuration under display button in the dimension tab to leader.  Rotate till arrow(s) are in the desired orientation and change back to linear.  A bit of a round about way to do it, but that is the way many things go in CREO.
3 REPLIES 3
kdirth
(To:ptc-170698)
ptc-170698
3-Newcomer
(To:kdirth)
Thank you kdirth! That worked fine.
  • select dimension
  • press right mouse button
  • use Edit Attachment command from context menu
  • move dimension to requested position
Martin Hanák
