I'm using Creo 5 and can't figure out how to mirror multiple components either. I can't believe this isn't available!? Does no one using creo make symmetric assemblies? Is it available in Creo 8?
Well, I'm off to make my 11 individual mirror features about the same plane.
There are multiple product enhancement requests for mirroring multiple components at the same time so i'm guessing it's not available.
The one that has the most votes is archived.
My workaround:
I will typically use an axis pattern 180 degrees around an axis that is central (almost everything I do is around a central axis) instead of mirror. I use it so much I made a mapkey to do it. You can also use an axis pattern on an existing pattern
I'm trying the same mirror command shown in the example. But in the examples shown, they are still selecting a single sub-assembly. I want to mirror multiple components and patterns that are not in a single sub-assembly.
My workaround:
While it's not the perfect solution, doing a circular "axis" pattern isn't a bad idea as a work around. It also solves an orientation issue I was having. It's not without it's issues though. A couple of notes on this approach as I tried it.
What a mess! But I guess it still beats unlink components and having to do double work when something changes.
Every so often, the axis pattern will have orientation issues as well. Generally, they are a sign of either a missing placement constraint or a "flaky" placement constraint.
The "gotcha" with most of these placement shortcuts (patterns, mirrors) is references after the fact. Any reference to a patterned or mirrored instance is prone to failure if the pattern is changed. The moral to the story is don't be haphazard with your references. Make certain you are working in the original placement area and not an area that is a patterned instance or mirror.
+1 a year later using Creo 7
Really PTC, you STILL do not have this feature? Solidworks has had this capability for YEARS.
