[Creo 7.0] Assembly mode - Can I pattern same parts in diferent directions?
For a long time I've thought about using Pattern feature for different directions. Let's say I'm in assembly mode, I've got a simple steel structure with many connector just exactly as below:
Now that's ridiculous to insert every single element (connector) separately part by part. So we can use the Pattern inside assembly mode of course. So we need to (or maybe not) use 4 Patterns because connectors are placed in different dircetions like in the following picture:
I'd like to use only one Pattern for this operation but still keep directionality of these connectors. When I pattern all connectors with one Pattern I'm unfortunately losing this directionality as follows:
Therefore I've got a few questions.
- Is it even possible to achieve that - using one Pattern and ain't losing the directionality?
- If the 1 point is impossible, what is the good practice for this example (and similar)? Should I create 4 Patterns separately?
- Is the good practice to use Patterns in assembly at all? Using it also has the downsides e.g. we cannot restructure parts/assms which are patterned (e.g cannot move existing Pattern to another assembly).
Thank you in advance for each reply!
