Greetings.
I am somewhat able to create a repeat region table containing all of the information I need. However there are certain issues which I cant seem to get past.
Problem 1 : I have a column for cable length, and I populated the top column with the following report string: &mbr.connprm.pin.run.len[.0]. 2 wires in particular is a part of a cable feature, one is displaying the proper length, one of which is not displaying anything. I did not manually assign any manual lengths, so I am now sure how to fix this issue, any ideas?
Problem 2: I have a different column, displaying length again, with the following report string: &harn.run.len[.0]. I have 3 wires as a part of a cable feature, each with varying lengths. In the table, only the longest length of wire is being displayed for all three wires. I am assuming that because this is a single cable, it is giving me the longest length in the wires, but whether I am right or not is what I was hoping someone would confirm?
Thank you for you help in advance.
Br,
Lars
Br,
Lars
