Creo 8 Freeze
Victor1970
7-Bedrock
Creo 8 Freeze
When click on symbols, balloons on drawing or weld symbol in the 3D annotation, Creo 8 is freezing and I have to "End Task" to close Creo and re-open.
My colleague open the same drawing and they have no issues.
Could be a config issue on my PC?
Thank you,
I deleted cache folder, my workspace and I added the server. Now it is working, no issues.
Thank you,
4 REPLIES 4
StephenW
(To:Victor1970)
You can check your config.pro(s) by temporarily removing (or renaming) and restarting creo. If the problem goes away, you then know it is a config problem.
This could also be an odd graphics issue. You can temporarily add the config option graphics win32_gdi and restart creo. If the problem goes away, then it is a graphics issue. Remove the option and update or find a graphics card driver that works.
Hi Stephen,
I am working remote on a VDI, I sent a request to IT and wait for response.
I will let you know.
Thank you,
Thank you,
StephenW
(To:Victor1970)
That's interesting. Some sort of corrupted cache.
Mark your answer as the solution so maybe it will help someone else in the future.
