Creo 9.0 Options greyed out in "Mechanism"
GS_10978309
I'm trying to create a spring in "Mechanism". What I did was I created two simple components in an assembly, and when the assembly is activated, I clicked Applications->Mechanism, and then a couple of options including "spring" are greyed out. in "insert" ribbon, only "servo motors" is available to select. All items in "properties and conditions" ribbon are greyed out. There is no "spring" option under mechanism tree.
I'm using Creo 9.0 Parametric. Can someone help?
Thanks!
@GS_10978309 wrote:
Due to my company requirements, I am using Creo 9 as well as Creo 10 but in Creo 10 these commands are visible and I can use them but Creo 9 these are not visible here.
in both versions do following:
Click File > Help > System Information > System Information
... and search for Mechanism Dynamics
I guess in Creo 10.0 you will see it -AND- in Creo 9.0 you will not see it.
If I am right then ask your IT to reconfigure startup command in Creo 9.0.
Martin Hanák
you need Mechanism Dynamics module license to have access to Springs.
Martin Hanák
Martin Hanák
Thank you, Martin Hanak for your help. I will do this also.
Hello @GS_10978309,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
