Creo Assembly BOM interface to Excel ... for FREE!
DavidBigelow
Just wanted to let you all know... the latest release of Nitro-BOM has a NO HASSLE - FREE LICENSE option...
  • Nitro-BOM enables direct customizable export of Creo Assembly Structure, Parameters, Values and even model data (e.g. current mass units, material file, simplified rep, etc.) and even map Creo Parameter Names to other Names... directly to Native Excel Tables.
  • Nitro-BOM also enables the creation, modification, deletion, designation/un-designation of Creo Parameters and can even rename models and drawings from ExcelFor example:
Simply Download, Unzip, Run.... and request a FREE License... NO REGISTRATION REQUIRED!
Nitro-BOM does require JLINK to be installed with Creo Parametric.  (instructions here if you need them)
The only difference between FREE and a Purchased License is the amount of content you can export or import changes for.  For most companies, the FREE License will be extremely useful.
Enjoy!
Dave
Download a FREE License here: https://simplifiedlogic.com/nitro-bom How to use Nitro-BOM to automatically compute Creo Parametric Assembly Cost Summaries by combining external ERP/MRP cost data using Excel Power Query. Highlights: - automatically extracting Creo Parametric Assembly BOM to Excel ...
0 REPLIES 0
