Hi @IAircraft_25,
There is no parameter to change the default naming convention of a cabling wire. You need to manually change the parameter names by going to Parameters in Route group in Cabling tab > Select a Cable/Wire/Ribbon > OK > select the name and type the new name in value column > Apply > OK.
Amol
Hi @IAircraft_25,
Amol
