Creo Hanged while Creating new dimension or moving a drawing view
kkamani
Dear all,
I am facing this problem from long time..
I have Drawing with some Imported Drafting lines from .dwg .
I this drawing when i place a new dimension or move a Exiting drawing view then creo will hang for 2 mins.
in status bar i found a message like " Entities do not form loops; cannot modify draft xhatching ".
I am using Creo parametric 2.0 M120.
Kishan
1 REPLY 1
Hi Krishan,
I just did a quick search on this. I found old case where a customer was having the same issue with a .dwg and the following document resolved the problem.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS108951
