Creo Model Check Errors Transfer from Creo to Teamcenter - IPEM
ashmech007
8-Gravel
There is a requirement that we need to send "Model Check" Errors from Creo to Teamcenter when Creo files get saved into Teamcenter .
Moreover I have observed that when "Model Check" Utility gets completed , Its generating a XML files in the local user machine ( For Example Windows Machine : C:\home\temp\mc_reports) where all the errors information mentioned in XML Format.
What are all the options that can be used to transfer the "Model Check" Errors from Creo to Teamcenter ?
So that while publish it check that file once .if error or warning exist user can rectify before publish the part.
1 REPLY 1
@ashmech007
I think this can be query for Teamcenter support...
