We had lots of issues with 7.0.5.0 and 7.0.6.0 crashing, to the point that they were not usable. We ended up staying on 7.0.4.0 until 7.0.7.0 came out. So far 7.0.7.0 has been rock solid. You might want to try installing 7.0.7.0 and see if the issue is still reproducible there.
Please
Thank you for the reply....
Please
Thanks Tom... I had installed 7.0.7 and it didn't correct the problem the first time.... Un-istalled and tried a second time and after a little tinkering, it seems to be working correctly again. Thanks!
