Creo Parametric 1.0
J.D.Mather
Creo Parametric 1.0
How do I set all sketch user dimensions to automatically be Locked?
I could do this in Wildfire but can't figure out how in Creo, I am having to right mouse button each dimension to lock.
JD Mather
Certified SolidWorks Professional
Autodesk Inventor Certified Expert
2 REPLIES 2
> dimension to lock.
Have a look at the following config options:
sketcher_dimension_autolock
sketcher_lock_modified_dims
> JD Mather
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
I thought I used a better title for this thread - but in any case,
For those who might be learning Ribbon interface I found dialog box for changing the setting.
JD Mather
