Hi Everyone,
I have added one column in the model tree that I need to get into the Parameter. Is it possible?
Aj
hi the following article https://www.ptc.com/en/support/article/CS377434 states that dispalying Model Tree column "Dependency Status" in drawing Repeat Region is not part of Creo Parametric functionalities.
@remy Thanks for the response, but I am looking for the Windchill Table. It's possible in there.
Aj
Regards,Aj
please attach a picture showing "Windchill Table" in which you want to display column Dependency Status.
@MartinHanak Thanks for the response.
I want the CAD EBOM structure table or the associated WT Part EBOM structure.
AJ
AJ
I do not know the answer. Please ask directly PTC Support.
Hi @Amirtharaj_K,
