Creo Parametric - Solid Welding in table
jżołądź
Hello!
Do anybody know why when I put some solid welds on my assembly it is shown as separate part of assembly in my drawing?
2 REPLIES 2
Most welded assembly BOMs are not complete without the weld material details, so by default Creo list the welds as separate parts. You can exclude them if you don't need for your BOM.
The problem is that in BOM table there shouldn't be weld feature.
The same problem is when I do weld table, because there are also normal components with weld feature.
This is the case on documentation witch was made some time ago. Lastly I add some welding feature on assembly and the problem schows on drw. But when I do new drw from the same assembly the problem dissaperes. I dont andestand where is diffrentce.
