Creo Parametric Student Version Drawing Template Frame
MS_11022618
2-Explorer
Hello everyone,
I've been working as a working student with Creo for quite some time now, so I decided to use it for a university project. Therefore, I downloaded the Creo Parametric Student 10.0 version and I'm on the verge of despair because I can't seem to find or insert a drawing template frame.
Unfortunately, the download didn't come with any frames or title blocks, and after intensive internet research, I still couldn't find any. I've already gone through all the relevant posts here as well.
Can someone help me and provide an A2 or A3 frame for this version? I've already manually created the title block according to ISO standards, but I can't find the exact data for creating the frame with letters, etc.
I would be extremely grateful for any help!!!
Y_Yoely
(To:MS_11022618)
Hi @MS_11022618
Have you tried the formats in the path: C:\Program Files\PTC\Creo 10.0.4.0\Common Files\creo_standards\formats?
12 REPLIES 12
This Creo Parametric tutorial video shows how to create a new drawing format, including: * importing DXF * system and user parameters * adding symbols and notes For more information, visit https://www.creowindchill.com. If you learned something from this video, please give it a thumbs up. If you ...
This Creo Parametric tutorial video shows you how to create a drawing template to automate and speed up the process of creating 2D production drawings for parts and assemblies. It covers such topics as: Converting a drawing to a template Importing a format Defining template views Making tables for
Y_Yoely
(To:MS_11022618)
Hi @MS_11022618
@Y_Yoely wrote:
Hi @MS_11022618
I guess that formats cannot be opened in Creo using Student license.
Martin Hanák
Y_Yoely
(To:MartinHanak)
@MartinHanak , These formats can be opened with any type of license.
did you test it?
Martin Hanák
Y_Yoely
(To:MartinHanak)
Yes
my last comment ...
You mentioned path: C:\Program Files\PTC\Creo 10.0.4.0\Common Files\creo_standards\formats.
This belongs to Creo Parametric 10.0.4.0. Unfortunately students can download Creo Parametric 10.0.0.0, only.
Martin Hanák
Y_Yoely
(To:MartinHanak)
So it is found in path C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\formats
try this link
http://apps.ptc.com/schools/references/templates.zip
Martin Hanák
Hi @MartinHanak
The ZIP file you shared does not contain the drawing format (.frm), so the drawing templates (.drw) do not even have a frame. As a result, it is not possible to create standard-compliant drawings from them.
@ProFeature wrote:
Hi @MartinHanak
my comments on your complaint follow ...
  • drawing template does not need to refer to the format
  • I did not share any zip file ... I provided link to package of templates provided by PTC, only
  • I did not check package contents
  • I am not responsible for what PTC provides
Please don't reply to my comments.
Martin Hanák
