Hello everyone,
I've been working as a working student with Creo for quite some time now, so I decided to use it for a university project. Therefore, I downloaded the Creo Parametric Student 10.0 version and I'm on the verge of despair because I can't seem to find or insert a drawing template frame.
Unfortunately, the download didn't come with any frames or title blocks, and after intensive internet research, I still couldn't find any. I've already gone through all the relevant posts here as well.
Can someone help me and provide an A2 or A3 frame for this version? I've already manually created the title block according to ISO standards, but I can't find the exact data for creating the frame with letters, etc.
I would be extremely grateful for any help!!!
Hi @MS_11022618
Have you tried the formats in the path: C:\Program Files\PTC\Creo 10.0.4.0\Common Files\creo_standards\formats?
I suggest you to use Youtube search, e.g. https://www.youtube.com/results?search_query=creo+create+drawing+template+
Please play following videos
https://www.youtube.com/watch?v=lGT85r_f8Dw
https://www.youtube.com/watch?v=3M5-UgG2PUk
Hi @MS_11022618
@Y_Yoely wrote:
Hi @MS_11022618
I guess that formats cannot be opened in Creo using Student license.
did you test it?
Yes
my last comment ...
You mentioned path: C:\Program Files\PTC\Creo 10.0.4.0\Common Files\creo_standards\formats.
This belongs to Creo Parametric 10.0.4.0. Unfortunately students can download Creo Parametric 10.0.0.0, only.
So it is found in path C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\formats
try this link
http://apps.ptc.com/schools/references/templates.zip
Hi @MartinHanak
The ZIP file you shared does not contain the drawing format (.frm), so the drawing templates (.drw) do not even have a frame. As a result, it is not possible to create standard-compliant drawings from them.
@ProFeature wrote:
Hi @MartinHanak
my comments on your complaint follow ...
Please don't reply to my comments.
