Creo Part file-Password Protected- Open challenge to all
AnandKumar
Hello All,
Please find below the attached file "frame.prt". This creo part has an parameter named password .
you can see the features of part only by providing the right password followed by model regeneration.
Good Luck.....
Regards
Anandkumar P
9 REPLIES 9
TomU
(To:AnandKumar)
Piece of cake.  No password required.
It's worth repeating again, if you can physically open it, you can do anything to it.  There is no way to protect a Creo model once it's been opened.
AnandKumar
(To:TomU)
I will create something special ...that is bit hard to find..
Regards
Anand
It will only work if you can stop us from editing the PRO/Program.
I just simply opened your part, edited the PRO/Program, removed the IF statement with the PASSWORD and regenerated the part.
It took me less than 3 seconds 🙂
AnandKumar
(To:TomU)
Try this case....
Creo Model Lock- Features Hidden
I found it. its quite interesting to find.
Find below attachment
Mani..//
anhcodon01
(To:AnandKumar)
Can you please guide me to unlock it. I tried to open it within 2 months but failed.
Open the part, edit the PRO/Program and remove the IF statement with the password, then regenerate.
anhcodon01
(To:HamsterNL)
Thank you very much! This is the best thing about Creo software that I have ever learned.
https://community.ptc.com/t5/Creo-Parametric-Ideas/Creo-File-Password-Protection/idi-p/799582
Vote here if you want the password protection functionality
